How to find out which WebI Reports are using which Universes
Hello,
We have about 400+ WebI reports and about 12 Universes. How do I get a list of all these WEBI Reports and what universes they are using in a single file?
something like this:
thanks
exile (BOB member since 2008-05-03)
You cannot use the Query builder because you must run several queries.
Make a search on BOB there is a tool call webi scanner…
i have not yet tested myself so do let us know how it goes:
Return Webi Reports Connected to a Specific Universe
 SELECT
SI_NAME, SI_WEBI, SI_DATACONNECTION
FROM
CI_APPOBJECTS
WHERE
SI_KIND = ‘universe’ and SI_NAME = ‘Universe Name’
The query above returns all the WEBI documents assigned to the Universe by specifying the following information:
SI_NAME: The name of the Universe.
SI_WEBI: The list of Webi documents assigned to the Universe by SI_ID.
SI_DATACONNECTION: The data connection assigned to this Universe.
To list the Webi report names run the following query:
 SELECT
SI_NAME
FROM
CI_INFOOBJECTS
WHERE
SI_ID IN (ID from SI_WEBI, ID from SI_WEBI)
twenty5 (BOB member since 2008-01-22)
R bhai? mu-hahah (ahem guys, sorry)
These query can get you what you need.
[1] To get everything:
SELECT * FROM CI_INFOOBJECTS WHERE SI_KIND = ‘WebI’
[2] Partially important stuff
SELECT
SI_ID, – WebI Report ID
SI_NAME, – WebI Report Name
SI_DESCRIPTION, – WebI Report Description, if any
SI_UNIVERSE, – Universe ID
SI_OWNER, – Report Created By
SI_CREATION_TIME, – Created ON
SI_UPDATE_TS, – Last Updated ON
SI_LAST_RUN_TIME, – Last Run ON, if ever
SI_CHILDREN – Instances, if any
FROM CI_INFOOBJECTS
GROUP BY SI_UNIVERSE
– ONLY Other problem is SI_UNIVERSE has 4 cells and the actually Universe ID is not the 1st cell, but on the 4th cell and thus the Group BY doesn’t really work very well.
Hi Twentyfive,
I ran the same query (SELECT
FROM
CI_APPOBJECTS
WHERE
SI_KIND = ‘universe’ and SI_NAME = ‘Universe Name’ ) but everytime it is telling me that ‘this is not a vlid query’. Could you please help me?
Philip (BOB member since 2006-03-02)
Try this query submitted by Mak 1. Works like a charm.
BoB LoblaW :us: (BOB member since 2007-10-23)
