how to find number of days between in particualr period
hi,
I have small issue, i have two dates, “starting” and “ending” date so i need calculate number of days between these starting and ending dates without includes Saturday and Sunday.
i have “day” object means sunday,monday…like and year,month,week objects also there.
Please help me!
i want this in report level. Starting and ending dates are my prompts and objects also.
ex: starting date is 01/01/2008
ending date is 01/08/2008
i used daysbetween(starting date;ending date) but how to eliminate saturdays and sundays.
iam using webi
srinu.bos (BOB member since 2007-06-06)
What database are you connected to?
Depending on the database theres probably a bunch of functions you could use in your Universe.
Other than that youd have to write a formula to loop round each day in the date range and check whether its a weekend. Given that Webi doesnt support control structures like loops youd have to do it in the database in a user defined function.
Unless someone else knows of a built in Webi function that does it.
thanks for ur response,
iam using sql2000 server.
please try any chance is there in report level or universe level to find this solution.
Try this clever Deski example and see if you can translate it to work in Webi:-
https://bobj-board.org/t/73436
:? hummm… interesting problem !
Don’t you think you can’t resolve this by a crazy smart calculation ??
each 7 days you have a saturday and a sunday and you know the starting day (monday, tuesday, etc…) and the same thing for ending…
cheers :wink:
kenny :fr: (BOB member since 2007-01-02)
I want to move this topic to the correct sub-forum of “Building Reports”. Since you don’t say what version you are using, I’m taking a guess and moving it to WebI XI. If I guessed incorrectly, use Report-A-Post (Red Exclamation Point icon) to request it to be moved again.
This post may help:
David P. :us: (BOB member since 2010-11-09)
