How to find how many reports were using 1 particular object
Hi Experts
we have a requirement on finding DEPT Object was used in multiple reports.
DEPT object is coming form Universe.
How to find out how many reports are using one particular object.
we are in BOXI R3.1 SP5.
I saw many forums about this issue. unfortunately it didn’t work.
Madu :us: (BOB member since 2008-02-08)
Any experts can help on this issue. I’m spending more time on research.
Basically I’m trying many ways from “Business Intelligence platform - Query Builder”.
I could find Object Name (column name) to filter for webi reports.
Either use a tool like Metadata Manager or write a Java SDK program to get this information from each report. Query builder doesn’t contain this information.
From a high level with the Java SDK:
  1. Query CMS for all webi reports.
  2. Loop through and open each webi doc.
  3. Loop through each data provider
  4. Check for combined queries because you need to recursively loop through them
  5. Loop through the result objects using getResultObject() method, loop through the condition objects using multiple methods because of the complexity of rankings and subqueries checking for the object and parent folder of the specified object in the universe
  6. Output report information you want when a match happens to file or database.
bdgeise (BOB member since 2011-12-15)
