How to Extract Xcelsius dashboard Metadata
hi,
i want to know if there is any query to extract metadata of the created dashboard using Query Builder Xcelsius dashboard 4.1
for example: to extract metadata from Query as a web Service(QaaWS) this query is used in query builder --> SELECT * FROM CI_APPOBJECTS WHERE SI_KIND=‘QaaWS’ <-- similiarly i want to know if there any query for Xcelsius dashboard
or Is there any Rest api present to extract metadata from the Xcelsius dashboard.
i have created a dashboard using the universe data i.e “eFashion” now i want to extract the metadata like Dashboard name, modification date, owner , query name, object name etc. from the Xcelsius dashboard
please Reply
Thank you,
asharma (BOB member since 2017-05-23)
