The substitution parameters are repository specific and stored in the repository itself. Here’s a query that can be used to extract the raw source code used by Data Services for storing the substitution parameters:
SELECT AL_LANGTEXT.TEXT_VALUE
FROM AL_LANG
JOIN AL_LANGTEXT
ON (AL_LANGTEXT.PARENT_OBJID = AL_LANG.OBJECT_KEY AND
AL_LANG.NAME = 'subvar_store')
WHERE AL_LANG.VERSION = (SELECT MAX(subq.VERSION) FROM AL_LANG subq WHERE subq.NAME = 'subvar_store');
The result set will contain multiple rows. You will need to concatenate those rows into a single string. If you were to do that and pretty it up here is what it would look like:
CREATE __BODI_SUBVARSTORE
SET ("SV_Config_Default" = 'Configuration1',
"SV_Config_Values" = '<?xml version="1.0" encoding="UTF-8"?>
<SVConfigurations>
<SVConfiguration name="Configuration1">
<SubVar name="RefFilesAddressCleanse">D:/BODS/DataQuality/reference_data</SubVar>
<SubVar name="RefFilesDataCleanse">D:/BODS/DataQuality/datacleanse</SubVar>
<SubVar name="RefFilesGeocoder">D:/BODS/DataQuality/reference_data</SubVar>
<SubVar name="ReportsAddressCleanse">YES</SubVar>
<SubVar name="ReportsMatch">YES</SubVar>
<SubVar name="SamplesInstall">D:/BODS</SubVar>
<SubVar name="CertificationLogPath">D:/BODS/DataQuality/certifications/CertificationLogs</SubVar>
<SubVar name="CompanyName"></SubVar>
<SubVar name="CompanyAddress"></SubVar>
<SubVar name="CompanyLocality"></SubVar>
<SubVar name="CompanyRegion"></SubVar>
<SubVar name="CompanyPostcode1"></SubVar>
<SubVar name="CompanyPostcode2"></SubVar>
<SubVar name="CompanyPhone"></SubVar>
<SubVar name="CompanyNAICSCode"></SubVar>
<SubVar name="USPSNCOALinkPlatformId"></SubVar>
<SubVar name="USPSProviderLevel">NONE</SubVar>
<SubVar name="CDC_NAME">SURF_ACTIVITY_TEST</SubVar>
</SVConfiguration>
</SVConfigurations>');
The same data is also stored in AL_LANGXMLTEXT and can be queried this way:
SELECT AL_LANGXMLTEXT.TEXT_VALUE
FROM AL_LANG
JOIN AL_LANGXMLTEXT
ON (AL_LANGXMLTEXT.OBJECT_KEY = AL_LANG.OBJECT_KEY AND
I don’t think the XML version is any easier to work with.
eganjp
(BOB member since 2007-09-12)
(BOB member since 2015-06-28)
