How to export jobs along with datastores ?
Hi ,
In a migration porject, can we export the old ETL jobs to a new project and edit them and run them ? How to export these and are there any issues in doing so ?
Can we change the datastore properties and import them back again into the repository ?
8)
jbodi (BOB member since 2011-09-07)
2 Things about Export:
  1. Exporting the entire repository into an .atl file like
    Right-Click in a blank space in Local Repo–>Repository–>Export to file and you could save it as an .atl file or .xml file also
  2. Exporting individual Jobs/WorkFlows/DataFlows/Custom Functions/File Formats/DataStores individually the objects or with their dependents using
    Right-Click on the specific object–>Export and a Window would open on the Right Pane and you could include/exclude specific objects
One thing you cannot do for sure is Exporting a Datastore and changing its parameters. Especially passwords you cannot, because they are encrypted when you export.
Again, the Technical Manual should help you lot more.
I got them to export. It worked fine and if i want to import them I tried by import from file …but nothing happened but data services struck.
How shall import other way ? and see if they work if i try to run?
How much jobs you exported? I think you are exported very huge. Why don’t you use the concept of Central Repository for this?
I just tried with a small test DF 1 table mapped to a query and to a template table.
I wanted to see how would this work if i want to change to diff, repository along with with new data stores
If you don’t mind can you explain the requirement of changing the Datastore? This part I am really not able to catch up?
Inspite of that, the Designer shouldn’t hang for importing such a small DF… What shows up in the Task Manager when you import? See how the AL_Designer.exe grows to? And see the CPU Graph…
I need to show dat a job can be exported as an ATL instead of creating a same new job again.
But while doing so i need to put a different table as a source in the imported ATL.
Practically, directly you cannot change the sources the way you request. Still I am not clear of the reason.
Only way is to manually change the Table.
But there are plenty of concepts like Aliases, Datastore Config with which we can play around.
What if I replicate a previous job and use it for a different job as the logic is same, but concern tables are reloaded with different datastore ?
Can I do that or do I need to do all over again developing ? If Yes are there any issues I need to make before I start to replicate one by one ?
Thanks in advance.
So are you going to load the table with exact same names from a different Datastore? Why should you do that? Why don’t you use the various Datastore Configurations for that?
In the same Datastore, you can configure a 2nd Database connection and use it.
Only thing is if your tables changes then the only solution is manual development/modifications.
