How to export crystal reports to BO repository
How to export crystal reports to BO repository and how can we check same report in infoview. can anyone suggest me the steps
vsr.2k :us: (BOB member since 2012-04-05)
If you want to export or save to BO repository ,
FILE >> SAVE AS >>> Click ENTERPRISE ( Left Hand side 5th option ) >>>
Enter the BO credentials and Save the required Folder.
Open the Infoview and view the report from the required folders.
Hope this helps!!!
RUC :us: (BOB member since 2010-05-03)
