Hi all,
I’m trying to execute a BW Process Chain through the Data Services. Is not a Open Hub Process Chain, ok?
It’s possible?
I already did this calling a event in the SAP, but I’m searching other possibilities.
Thank you,
Vinícius F.
ViniciusFossaluza
(BOB member since 2009-09-02)
system
2
check the following post, it talks about similar thing, there are not replies for that
check the following this has some discussion, see if that helps
system
3
Hi manoj_d,
I’m still trying to solve the problem.
Thank you again!
Vinícius F.
ViniciusFossaluza
