We have one general Supervisor, that is been disabled, we dont have other General supervisor user to enable that.
So please give me the solution how to enable a general supervisor
John
john81 (BOB member since 2005-06-07)
John
A simple search for disabled general supervisor would have found you a bunch of results.
Start with this one: FAQ: Supervisor
Steve Krandel (BOB member since 2002-06-25)
Thanks for giving solution, i tried to chage the following
Update OBJ_M_ACTOR
Set M_ACTOR_C_PASSWORD = NULL
Where M_ACTOR_C_NAME = ;
and changed the M_ACTOR_N_STATUS=1
now in user properties Disable user is blocked.
pls give me a solution
John
You can never disable a general supervisor id from supervisor. You either delete it or it gets disabled because of a password issue.
There is no solution to this. This is how it is supposed to work.
