Hello Phorum,
i want to see in my report rows which contain fields(cells) that have empty values.
Thank in advance
brisou (BOB member since 2004-07-13)
Hello Phorum,
Thank in advance
I’m not sure I’m with you… When you show data in a report, null values will appear as an empty cell unless a custom format has been applied which shows something else.
Paul Williams (BOB member since 2002-07-10)
I’m guessing this is the classic “I want to show all months, even if there is no data for that month” question. It may not be months, but some other dimension, but the technique is the same. Start with this FAQ entry, and also do a search for “show all months” or similar to see many past discussions.
Dwayne Hoffpauir (BOB member since 2002-09-19)
Is this an inside joke about Forums?
Anita Craig (BOB member since 2002-06-17)
