hi all
i was wondering if it is possible to use drill down on MEASURE if it is NOT created locally???
rola_jutt (BOB member since 2005-09-29)
hi all
If you mean, to split a calculation into it’s components… No.
Drilling in general doesn’t make sense on measures. You drill on dimensions. Drilling is about hierarchies of dimensions.
Steve Krandel (BOB member since 2002-06-25)
thank you mr Krandel for your reply,
thats correct it does not make sense, but lets say we have a MEASURE by the name COUNT(of customers ), wat if we want to see the names of customers whose count is this… using drill mode???
Lets say you have count of customers in a particular region. Then you might want to drill on region to show the customers associated with a particular region instead of trying to drill on the count.
Hope this makes sense.
Prateek Shah (BOB member since 2005-07-24)
You should be looking at the OpenDocument function, see this topic for starters
Andreas (BOB member since 2002-06-20)
