HOW TO DO....
Hi all…
i’ve just one question…
there is some product who allowed to control if one table or on objetc is used in one or more Report?
or i must open one by one reports to see if tables or objects matched?
some one can help me?
thanks
Barticchia :it: (BOB member since 2008-06-09)
I think you’re asking us to let you know if there is any utility which gives you the list of objects used in the reports? If yes, then it is the time for you to use this utility from BOB downloads.
