How to do WildCards
Hello All,
I want to achieve this request:
Need a report that would work in a manner similar to Customer Search, but based upon addresses.
1)Able to use wild cards in case of misspellings
2)Be non-case sensitive in the search field
3)List the matches the same as Customer Search.
FYI, I have Addresses object.
Thanks for your help.
Pooja
ktm :us: (BOB member since 2008-11-12)
What is Customer Search?
Look at the Upper() and Match() functions.
Hello Nick,
Thanks for your reply.I drop the address object into the Query filter and make Address Match pattern"Enter Address" as prompt.
Is this the way to do?How can i use the Upper() function.
Basically they want prompt which allow them to fetch the data based upon their inputs.
Pooja
Pooja,
I think you will have to create a condition in the universe roughly like below:-
ucase(Address_object) = ucase(@prompt(โ€˜Enter the address:โ€™))
Note - ucase is for oracle
Cheers.
BO_Stuffed (BOB member since 2008-03-29)
