I am working on XIR2 ,In my Reports i have to display Euro Symbol with values.How should i get Euro Symbol as I don’t have in my keyboard, any suggestions please.
br81 (BOB member since 2007-07-04)
You want to disply total amount along with your calculated value then follow steps…
Hope this helps you…!!!
srijaggu (BOB member since 2007-09-07)
Using Alt+0128 gives you
Also, depending on your PC setup, AltGr+4 gives €.
About the only use I’ve ever found for that key…
Paul Williams (BOB member since 2002-07-10)
When I download a Webi report into Excel that has a Euro € symbol in it converts it to just a line ? Anyone else have this problem whats the resolution ?
Fiona (BOB member since 2002-12-16)
