How to display CLOB in the reprot?
I defined the object for CLOB field as Longtext.
While I am trying to add that field in WEBI query panel, its showing an error as inconsistent types.
What would be the way to display data of CLOB type data in the reports?
GowthamSen :india: (BOB member since 2006-08-31)
Go through this and see whether it helps you.
Hi Jansi,
Thank you very much. :lol:
It worked!! :wave:
