How to disable sort in Grid?
I am using List view grid in my report.i want to disable the sort in the grid.Please suggest a solution for this.
vineeta04 (BOB member since 2009-01-05)
You can place a Background top of the header with 100% transparency(in 4.5 it is set to 0)
I hope it help
dandamudi :india: (BOB member since 2008-07-03)
Can you be more specific?Please tell where exactly do we need to set this property?
Sorry this is not available option in List view but we can get by using Background component
Place a Background component(you can Under the component panel —Arts and Backgrounds).
Hope this Helps…
keep one background component on top of the grid header area
and “check” the option “Block Mouse events” in general properties of background component.
then keep transparency as 100 % in same general properties and apply the same display key if you have any for grid component.
i hope this will helps you.
Santhosh.
bandelasanthu :india: (BOB member since 2008-03-06)
Thanks a lot!! This works but there is another problem.I have a drop down which falls at the same place where I have placed the background to disable the sort.Due to this I am not able to select the value from the drop down at that particular point.
you can overcome this by arranging the components in the object browser.
as
Listview
Background
Dropdown list.
Santhosh
