how to delete failed instances?
i have a webi report which is scheduled at 2am everyday. During the last daytime savings, for some reason, the instances got filed and hundreds of instances got scheduled/failed.
i have deleted that recurring schedule and recreated one at a different time which fixed the issue.
how can i remove the failed instances for this report, from the history?
i can’t do it page by page as there are so many of them. is there any other way to delete directly from the server?
polaant :us: (BOB member since 2006-08-08)
See my reply on page 3 of this thread, or this one.
Joe
polaant …Did you find a solution to this? I’ve something similar and there are thousands of old instances. Looking for a way to remove the past instances… Deleting manually page by page sounds like terrible idea. :hb:
bobjquest :australia: (BOB member since 2012-04-01)
Did you look at the threads I linked to above?
