I have two 3 tables tableA,B and C Table A and Table B join is Inner but I want to make the join from Table B and C left outer join. How do i need to set this cardinality?. THanks so much. I am using XI r2
Thanks in advance.
Lori
The cardinality is largely irrelevant. But, if you look just above where you set cardinality, there is a little checkbox below the listing of the fields for each table, called “Outer Join.” Just tick this on for whichever table you want to have the outer join.
