I created a batch job with one Dataflow.In this Dataflow I have :
A Row Generation transform to create one record
A Query transform
A Query transform
A Query transform
Finally, I load a target table with the result
When I execute the job with the DataStore (Web Service) I get an error :
And get the below error
(14.0) 03-23-12 18:11:19 (E) (4576:14020) VAL-030258: |SESSION JOB_TEMP|WORKFLOW WF1|DATAFLOW DF_WEB_SRVC|STATEMENT <GUID::‘6a4fc48a-4c74-4298-8ac1-7ed1ff99534c’ LOAD TABLE OVSTG_DS.OVSTG.WEB_SRVC INPUT(Query_2)> Input to target <WEB_SRVC> contains column that is a nested table type. Input to loader cannot contain a
column representing a nested table.
Can someone please advice me how to unnest. A sample logic.
Thanks in advance.
Add a new query before the loader. In this query drag all columns and schema from the input to the output. The schema elements you rightclick and say “unnest”.
Your function has a schema called findall and it contains two columns, pageindex and noofrecords.
Hence you have to pass a schema into the function, one that has those two columns as well. So you will need an upstream query where you create the schema and the columns accordingly - see Wiki for the details.
I have created one schema and two cols in the upstream query and have fed it into the function call of the webservice.
Now I get the below error
[Query:QRY_GET_ROW_ID]
No columns defined for target schema. (BODI-1111079)
(Attached the screenshot of the error)
[Function Call:DS_WEB_SRVC…FindAll]
NRDM Function <Cannot parse expression.
In call to adapter function , the number of columns for nested table is <2>, while the input nested table has <0> columns. Ensure that the number of columns is identical… (BODI-1112351)> (BODI-1111191)
