Here is some back ground.
BOE oracle.prm file.
Default format:
DD-MM-YYYY HH24:MI:SS
Changed to:
DD-MMM-YYYY
Oracle NLS_DATE_FORMAT setting in Oracle.
DD-MON-RR
We use this literal format in our SQL commonly to achieve static pruning.
DD-MON-YYYY
Example using BOE Oracle default.
–alter session set NLS_DATE_FORMAT=‘DD-MM-YYYY HH24:MI:SS’;
select
from clarity.clarity_tdl_tran tran
where tran.post_date = ‘16-12-2014 00:00:00’
Example using new format in BOE to match the Oracle NLS_DATE_FORMAT.
select
where
tran.post_date = ‘16-DEC-2014’
The Explain Plan cost was 13757 in the 1st case and 19 in the second which was a dramatic improvement. Basically, we needed to drop the time in the parameter to match the Oracle default NLS_DATE_FORMAT. The downside is that we cannot put time in the Where Clause WEBI filter, but I think we can live with that to gain the benefit of static pruning in Oracle.
From your original post, I didn’t think it would be related to NLS settings on the Oracle side.
Very few people want prompts with time stamps in any case, as they are too granular.
Here is some further explanation of why we want a different Oracle date format.
When we partition a table by date in Oracle we use this mask ‘syyyy-mm-dd hh24:mi:ss’.
When we use the NLS_DATE_FORMAT or include a TO_DATE with a mask.
Either tran.post_date = ‘16-DEC-2014’ or tran.post_date = to_date( ‘16-12-2014 00:00:00’,‘DD-MM-YYYY HH24:MI:SS’) then the Oracle optimizer does access(“TRAN”.“POST_DATE”=TO_DATE(’ 2014-12-16 00:00:00’, ‘syyyy-mm-dd hh24:mi:ss’)) which does static pruning while with the BOE Oracle default it does not.
select – BOE Default
where
Explain Plan result.
4 - access(“TRAN”.“POST_DATE”=‘16-12-2014 00:00:00’)
select – NLS_DATE_FORMAT
where
4 - access(“TRAN”.“POST_DATE”=TO_DATE(’ 2014-12-16 00:00:00’, ‘syyyy-mm-dd hh24:mi:ss’))
select – Add a TO_DATE with mask
where
