How to consolidate Data from two different Workbook ?
Hi Xcelcius User …
I have a situation in which I have to take data from two different work book (Work book 1 ,2) and consolidate into one .
Can you please let me know the different ways to achieve this .
Is it possible that data in workbook 1 gets updated the consolidated one gets updated automatically .
Right now in both the sheet the data is captured manully.
Swapnil
swapnil_taz :india: (BOB member since 2006-04-06)
You can only use one Excel workbook (file) as a data source in Xcelsius. Why do you need to have 2 separate files? Since the data is static as you say then you have to either combine the two workbooks before importing the Excel file into Xcelsius.
J0sh :australia: (BOB member since 2006-10-09)
You cannot use two different Excel doc for the same document.
Combine the data from two different excel workbook into one and Export the sheet from Data -> Export
Let me know if you need further help.
neel22 (BOB member since 2009-05-15)
