I have 2 separate universes. The 2nd universe should have been created
as new classes and objects within the 1st universe, but instead was
created as a separate universe. Is there a way to merge the 2nd
universe into the 1st universe? (the 2nd universe will go away, the
result being 1 single universe with all tables, classes and objects from
both universes). I know how to make both universes available to users and
how to use both universes to create a single document, but I actually want
the universes combined into one.
The tables do not overlap between the universes, but are all located in
the same database instance (Oracle). However, there may be some objects
that are named the same between the 2 Universes. The 2nd universe is
not too large, so I could go in and rename any objects that might be
named the same as the first universe. I will be able to manually set the
joins between the new tables brought in from the 2nd universe to the
tables in the 1st universe.
I’ve looked around on the CD, but haven’t found anything related to this
yet. Thanks for your help!
Kathryn Whiteley
Sr. Systems Analyst
The Seattle Times
