how to clean up prompt in webi report
Hello,
I want to make report very clean before I publish it but after I purged it and run it again the data I inputted in the prompt last time when I ran it automatically show up there. how can I clean it up so next time when this report is run nothing will shows up in the prompt box?
Thanks in advance,
mimi
mimi (BOB member since 2005-05-06)
If it is report level prompt, you can go and uncheck “Keep last values Selected buttion” check box.
vrrm (BOB member since 2008-08-04)
Vrrm,
Thanks so much!!! it works.
mimi
