I’m very new to xCelsius (< 1 week), and I can’t find the answer to my question anywhere.
I’m using QaaWS to return data to be displayed, and I want to set up alerts on it. The idea is that there are a list of 60 indicators, and when you choose one of the indicators, another QaaWS is fired to get the last 30 days history for this indicator. This data is numeric, and is designed to be shown in a graph. Associated with each value, is a colour, Red/Yellow/Green (I can also return the low/high values if needed). What I’d like to do is then use the alerter capability to highlight the data in Red/Yellow/Green where the associated value is red/yellow/green. I tried to use the “use a range” option, and it worked for some of the indicators. Where it fell down is that while for some of the indicators, “low values are good”, for some of them “high values are good”. Without figuring if that toggle can be set dynamically, has anyone managed to achieve what I want to do? Feel free to ask me questions if you don’t follow.
I’m using xCelsius 2008 Enterprise (SP2) with Business Objects XI 3.1 (SP2.1) in the background.
An example of the data would be
Indicator #1: Value 30: Colour: Green Red Low:100 Red High: 1000 Yellow Low 40, Yellow High 99, Green Low 0 Green High 39
and 29 more entries
Indicator #2: Value 17: Colour Yellow Red Low: 0 Red High 10 Yellow Low 11 Yellow High 20 Green Low 21 Green High 100
and 29 more entries
adrian.procter (BOB member since 2006-09-26)
