Hello everyone,
I would like to change the sentence on webi home interface(im on SAP BO 4.3), i tired to check all the files of configuration (.properties) but i still unable to change it.
Do you have some solutions ?
Thanks in advance.
Hello everyone,
Thanks in advance.
Check out the section on Customizing the Fiorified BI Launch pad.
I’ll leave the details to the referenced help link, but basically you need to create a FioriBI.properties in
<INSTALLDIR>\SAP BusinessObjects XI 4.0\warfiles\webapps\BOE\WEB-INF\config\custom with this line…
app.name.greeting=Whatever you want
In addition to the help referenced above, I also found this answer to an SAP Community question helpful.
Here is our result…
Noel
@nscheaffer thank you so much, your solution worked for me by adding app.name.greeting. ![]()
