system
May 11, 2011, 10:14am
1
My report is like…
Country Year
France 2004
France 2005
France 2006
US 2004
US 2005
US 2006
But I want to change like…
Contry Year Year Year
France 2004 2005 2006
US 2004 2005 2006
Can any one tell me the solution… But It should be a Vertical Table…
Awaiting ur reply.
Mahesh
mahesha (BOB member since 2011-05-11)
system
May 11, 2011, 10:20am
2
mahesha,
Welcome to B B!
Have a look at this post:-
https://bobj-board.org/t/175322
Mak 1 (BOB member since 2005-01-06)
system
May 11, 2011, 10:29am
3
Thanks for ur reply…
I need to change the structure only…
Mahesh
system
May 11, 2011, 11:02am
4
Hi Mahesh,
Hope crosstab would make this…
But Cross Tab header will be based on year and you can add measure value to it to display in cell.
lnarayanan86 (BOB member since 2009-08-05)
system
May 11, 2011, 11:04am
5
If i Use Cross tab, Header also coming like Year names…And more over i dont want to use Crosstabs…
Mahesh
system
May 11, 2011, 11:37am
6
As BO works based on each rows fetched from DB, i hope this will not be possible or will be too complex in BO…
Even I had a similar requirement but finally we gave up and provided solution to use min & max to show atleast two values…
You may acheive this by using Rank() over function and cross tabs.
Hope this helps you.
Regards.
Rmbodvp (BOB member since 2010-10-14)
Hi Shriram,
Thanks for ur reply,
I have more than 10 dimensions in that table , So if i change this structure to cross tab is not possible… I want to do in Verticle Table. Not in Cross tab.
Mahesh
Can you post the exact requirements?
Regards.
system
May 13, 2011, 10:02am
10
Hi Shriram,
PF attahced file.
Mahesh
system
May 13, 2011, 11:52am
11
You forgot to attach the file.
Rakesh_K (BOB member since 2007-12-11)
system
May 13, 2011, 12:04pm
12
Sorry,
Now u check
Table.doc (49.0 KB)
system
May 13, 2011, 12:19pm
13
Can you also mention the queries used here?
system
May 13, 2011, 3:31pm
14
How many years do you have? You can create a variable for each year, so for 2005, create a vartiable =[year]where([year=“2005”), then repeat for all your years. Sounds like a lot, but you can use the dubplicate variable and it actually goes quite fast.
rbacon (BOB member since 2011-02-03)
system
May 16, 2011, 4:44am
15
Create two separate queries and merge the dimensions.
system
May 16, 2011, 5:54am
16
Also check this thread:
https://bobj-board.org/t/175556
There is a Universe as well as report level solution.
BO_Chief (BOB member since 2004-06-06)
