How to call openDocument.jsp from my Java applicaiton ?
I read all the posts related to openDocument.jsp and I am using the below url to invoke my crystal report from Infvoiew.
http://:/businessobjects/enterprise115/desktoplaunch/opendoc/openDocument.jsp
I replaced the hostname with the server name and port as 8080
But still I get the error “The page cannot be found”.
Do we need to do any setting on the server to make it work ?
Any help is appreciated.
Thanks in Advance
Vinod
vinodk (BOB member since 2006-12-01)
Are you sure that your BO version is an XI? If yes, please check the application server. This URL will only work with J2EE ones (not with IIS).
Ghislain
ggouzy :fr: (BOB member since 2005-10-25)
Yes we are using BO XI R2 and Tomcat is the webs erver.
To call your report from the Java application there are 2 steps
1)Get an authenticated Token from BO
2)Pass the token and the report name/id in the opendocument url
have you done those two steps
Sheshachala5 :india: (BOB member since 2004-01-09)
