How to calculate Number of Business Days in Web Intelligence
Hello All,
I guess there is no direct formula to calculate Number of Business days in Web Intelligence XI R2.
 Is it possible to calculate number of Business days in Web Intelligence
Ex: ( It is some thing like DaysBetween() should exclude Holidays, while calculating days between two dates)
Thank you
Keerthana
Keerthana (BOB member since 2008-01-11)
If you need a calculation that excludes holidays you really need to do it with a calendar table in your database. Quite frequently people (companies) have different holidays, so you need to be able to set up your own.
Ignoring the holiday question, try this:
Ignoring the holiday question, I just wrote a UDF for a kick that excludes weekends in calculating # of days.
It may not be very impressive but here is the code:
[i]
create function dbo.fCountNoOfBusDays
(@bDate smalldatetime, @eDate smallDatetime)
returns int
as
begin
declare @loopCntr int
set @loopCntr = 0
while @bDate <= @eDate
begin
	if DATEPART(WEEKDAY, @bDate) not in (6,7)
		set @loopCntr = @loopCntr + 1
	set @bDate = dateadd(day,1,@bDate)
end
return @loopCntr
end
select dBeginDate, dEndDate, dbo.fCountNoOfBusDays(dBeginDate, dEndDate)
from
[/i]
sunjer (BOB member since 2008-01-30)
That would work in a universe, but not in a report.
it should :slight_smile:
the SQL for # of days will be:
Thank you all for your input on this query. I was busy with other issues at work. I will try to follow your approaches to calculate the difference between days.
Thank you once again
keerthana
