How to build dataflow (initial\delta) with extractor (V)
Hi!
I have extractor on the basis of table (V) with delta. I added extractor into the table ROOSATTR and imported into DS 4.0.
In the table ROOSOURCE, extractor delta type is AIE.
hence it ulr follows:
http://wiki.sdn.sap.com/wiki/display/EIM/Extractor+RecordMode
recodrmode is “”, therefore it is necessary to use comparison table?
http://wiki.sdn.sap.com/wiki/display/EIM/Dataflow+for+Extractor+Delta+Process+Type+AIE
Now i don’t understand how to use delta with comparison table transform.
Because, then on input my extractor on view and as comparison table i try to use ODS table, where data are loaded… i get the error: i cant use ods table as comparison table.
My be CDC map transform? But as far as I understand i cant used it, because no info about recordmode → and DI_OPERATION_TYPE cant define.
So, question: how to build dataflow (initial\delta) with myself extractor on view?
thanks.
shumer (BOB member since 2012-06-05)
Are you able to setup init and delta loads for your job. Currently I am facing the same issue.
Araj (BOB member since 2007-06-28)
