how to auto adjust the block position?
hi all,
i have a report in that i have 2 blocks(1 is tbale and other is crosstab) 1 for detail data and 1 for summary.
now i want to disply the summary table at the bottom with overall data on top.
i have a date prompt for the report so if user selects other date range than there will be more data in the first table,so it will overlap the summary tbale.
so is there any property known for setting autoadjust positon for the block?
can any one help me with this??
Biku724 (BOB member since 2008-07-29)
Use relative positioning for the 2nd table. Position it relatively to the 1st table.
The positioning of a table is set in the table properties, in the appearance tab.
From the Reporter FAQ:
How can I position report blocks relative to each other?
Thanks for the prompt response.that was helpful.it’s working…
