I have an xcelsius icon component and my requirement is to display the color depending upon the value/range in the excel sheet. Please help!
nkpriya (BOB member since 2010-05-04)
Hello nkpriya
WELCOME TO B B
Look at the Alerts tab in the properties of the Icon, and depending upon your display value, Alert thresholds, and range values, you will be able to set-up the color dependency. Lookup Xcelsius userguide on google for detail understanding, as this is basic knowledge.
katullus (BOB member since 2009-08-21)
Actually I know it can be done using Icon Alerts. But I am not able to display colors depending upon the range.
Btw, I am using Trail version. Thanks
