If you want to add the column in the table before the cross tab
(i mean before cross tab’s objects) then you can just add to the column section of the cross tab
else if you want to add after the cross tab objects then please click on teh cross tab objets then click on Sum and you will get the sum for each row.
So edit this row to get the new variable.
After such rows are added then you can just add a new row if you want to add and new column after this one.
Thanks for your help.
My point is not how to add a row, but how to define the formula of this row which does R/R=(Nb_fly(200601) - Nb_fly(200501)) / Nb_fly(200601)…
