system
April 1, 2010, 2:52pm
1
Wondering if someone can help me figure out how to extract the email addresses that a scheduled report will be sent to.
I begin by querying for the schedule info from a given report:
String query = "Select SI_SCHEDULEINFO From CI_INFOOBJECTS Where SI_ID = " + reportID;
from the returned IInfoObject I get the scheduling info:
ISchedulingInfo sched = obj.getSchedulingInfo();
from that I get the destination info:
IDestination dest = sched.getDestination();
now from this, I want to find all the email addresses but not sure how.
the following does not work:
for (int i = 1; i <= (Integer)dest.properties().getProperty("SI_DEST_SCHEDULEOPTIONS.SI_MAIL_ADDRESSES.SI_TOTAL").getValue(); i++) {
String address = dest.properties().getProperty("SI_DEST_SCHEDULEOPTIONS.SI_MAIL_ADDRESSES." + String.valueOf(i)).getValue().toString();
Any ideas or exmaples on how to iterate over the destination property bag?
Thanks!
Andrew Jones (BOB member since 2010-03-10)
system
April 1, 2010, 3:55pm
2
Here’s a snippet of how we retrieve email addresses from schedules.
hope it helps.
String query ="Select * from CI_INFOOBJECTS WHERE " +
"SI_NAME=" + "'" + reportNameSv + "'"+
" and SI_RECURRING='1' ";
try{
results = (IInfoObjects) iStore.query(query);
if(results.size()>0){
report = (IInfoObject) results.get(0);
// out.println("Report Name: " + report.getTitle() + "<BR>");
sched = report.getSchedulingInfo();
destination = sched.getDestination();
destPlugin = (IDestinationPlugin) iStore.query("select * " +
"from ci_systemobjects where si_parentId=29 and si_name='CrystalEnterprise.SMTP' ").get(0);
destination.copyToPlugin(destPlugin);
if(destPlugin==null) {
out.println("Unable to get DestPlugin");
}else{
smtpOptions = (ISMTPOptions) destPlugin.getScheduleOptions();
String s = smtpOptions.getToAddresses().toString();
String emailSender = smtpOptions.getSenderAddress().toString();
s = s.replace(',',';');
s = s.replace('[',' ');
s = s.replace(']',' ');
s = s.trim();
String x = smtpOptions.getMessage() ;
if(hasSpecialChar){
reportName = reportNameSv;
x = x.replace('^','$');
out.println("Message: " + x + "<BR>");
out.println("Showing Message Body" + smtpOptions.getMessage() + "<BR>");
out.println("Showing To Addresses" + smtpOptions.getToAddresses() + "<BR>");
//out.println(destPlugin);
else{
out.println(reportName);
out.println("No results found");
}catch(Exception e){
out.println("Error found " + e.getMessage());
jresendez (BOB member since 2004-05-03)
system
April 1, 2010, 4:13pm
3
Awesome, thanks!!
question, in :
select * from ci_systemobjects where si_parentId=29 and si_name='CrystalEnterprise.SMTP'
is that hard-coded value ‘29’ the id of your report or something else??
system
April 1, 2010, 4:35pm
4
after a few queries via the query builder i believe i know why si_parentid=29 is specified.
I executed the following:
select * from ci_systemobjects where si_id=29
this returned one record of SI_KIND=‘FOLDER’ and the SI_NAME for that folder was ‘Destination Plugins ’ (this already starts to make sense)
the record also indicated that it has an SI_CHILDREN value of 4
I retrieved the 4 children by the following:
select si_kind,si_name from ci_systemobjects where si_parentid=29
The children had SI_Names as follows:
[list]CrystalEnterprise.Smtp[/list]
[list]CrystalEnterprise.Managed[/list]
[list]CrystalEnterprise.Ftp[/list]
[list]CrystalEnterprise.DiskUnmanaged[/list]
so the additional criteria of ‘CrystalEnterprise.Smtp’ limits the original query to retrieving only the plugin information for the SMTP destination plugin.
system
April 1, 2010, 6:21pm
5
Ahha, good stuff!
That explains a lot. Thanks for the help and info
system
April 1, 2010, 7:10pm
6
[Moderator Note: Moving from XI Scheduler forum to SDK]
