How do you set default preferences for all users?
I need all new users to have a default view format of INTERACTIVE. How do I change those default preferences? Can’t find anything on it in documentation.
Thanks, Charlie
charliebrown :us: (BOB member since 2002-09-03)
maybe try search the forum first - this has been discussed many times.
In the downloads section there is a file you can download which does this for you.
blair :canada: (BOB member since 2006-11-17)
thanks for the response blair but the first thing i did was search the forum (on default view format and the like), and just did again and i can’t find anything. Can you point me in the right direction? And in regard to the download file, are you referring to BusObj support site?
ah! forget it blair. found it…
https://bobj-board.org/t/75331
I think this allows you to modify preferences of existing users. Thus you probably need to run this each time you create a user no?
That is correct.
Hi…
I am working on BOXI R2 SP2, linux
Is it possible to set the format to interactive.
thanks,
shiky (BOB member since 2007-07-11)
