How do I enable a "disabled" General Supervisor Ac
One of our General Supervisor accounts was disabled due to a bad password entry. When I opened Supervisor in 6.1.B, I could not enable this user, the option was disabled. Is this a bug? How do I enable this general supervisor account again?
JSanthanam :india: (BOB member since 2003-12-17)
Can only do it if you are logged in as a GS, then you just click the box Disable Login to remove the check mark.
Worked for me :wink:
Charles Killam :us: (BOB member since 2003-04-24)
Well, I am logged in as a GS and those options are still disabled. Why? I ended up manipulating the internal table directly (Yes, I know BO advices against it :slight_smile:
It is possible to re-enable the user via the repository.
A description of all of the tables in the domains of Repository can be found on the BusinessObjects installation CD: d:/Freeeware/repostry.htm.)
this should point you in the right direction
Reporter Bloke :uk: (BOB member since 2004-05-20)
Look at this FAQ. Next time, please, please search! the answer really wasn’t very far away :wink: :shock: :rotf:
