I have a report that has tabs for each country eg 1 tab for UK, 1 tab for Ireland, 1 tab for Italy etc. Currently there are about 8 country tabs and then an “other countries” tab that catches all of the countries outside of the main 8. The report was built by having 1 tab with all the countries on it, and then applying a filter to each one to only show the data for that country.
Now here’s the rub, the recipient has asked that I set the report up so that rather than the “other countries” countires being grouped together in one tab, they are split out in to their own separate tabs. I figure I can do this by using a macro that gets a distinct list of countries in the report, then loops through them creating a new tab for each one, based on the “master” tab with the appropriate filter applied.
Any ideas how I can do this? (Ideally I need a hand with the code syntax itself as my BO VBA pretty limited).
Cheers,
Fred
fred_easey (BOB member since 2005-05-10)
(BOB member since 2003-11-27)
