How do I display the correct price based on a max date?
HI all,
We have products with historic prices against them and each price has a date, I need to display the price based on the max price date. I’ve got the max price date showing correctly using the below
=Max([Price Date] In([P Code];[P Desc];[Price Date]))
but cant get [Gross Cost] to display the price I need, its either showing all of the historic costs or giving a multivalve error. Does anybody know what the correct syntax is required for this please?
I only want to see 2 rows:
This isnt working
I’ve lost touch with WebI for a while but I’d do it with a “HAVING” clause in the SQL.
SELECT CustomerID, CustomerName, Price Date
FROM Customers
HAVING Gross Cost = MAX(Gross Cost)
Or this one, but you have to use an “n” that will include all ties for first place.
FROM Customers
ORDER BY Gross Cost DESC
FETCH FIRST n ROWS ONLY
Depending on your DB…
– DB2
SELECT *
FROM table
FETCH first N rows only
– Informix
SELECT first N *
FROM table
– Microsoft SQL Server and Access
SELECT top N *
FROM table
– MySQL and PostgreSQL
SELECT *
FROM table limit N
– Oracle
SELECT *
FROM (SELECT * FROM table ORDER BY Gross Cost DESC)
WHERE rownum <= N
why are you switching from in() to foreach() ?
if there is a MULTIVALUE, try sum…, avg…, min… or max([Gross Cost])
something like =Max([Price Date] in{input context} in{output context}) might help
