Hello…
i was wondering about adding a shape-file to BO 4 dashboard designer, as a map object… is it possible without an addon??
also can a user add comments on a published dashboard?? (and save it?)
TDE_AF (BOB member since 2014-02-17)
Hello…
No, there is no way to add shape files to Xcelsius/Dashboards without an
add-in. Centigon Solutions is the best option for this.
As for adding and saving comments on a dashboard, this also cannot be done ‘out of the box’. The Local Scenario component lets a user save comments, but he could only see his own comments and not anyone else’s (hence the name "local’). You may want to check into 3rd party solutions for this as well, like InfoBurst which allows you to Writeback data to a database table and retrieve it instantly.
Hope this helps,
~RoxanneP
Sr BI Consultant
InfoSol, Inc.
RoxanneP (BOB member since 2006-08-07)
Depending on how you host your dashboard, it is possible to add and save comments to a dashboard.
For example, if you host your dashboard on an IIS server, you could write an ASPX script to take and input and update/write to a table.
Here is some sample code:
<%@ Page Language="VB" aspcompat="true" Debug="true" validateRequest="false" %>
<%@ Import Namespace="System.IO" %>
<%@ Import Namespace="System.XML" %>
<%@ Import Namespace="System.XML.XPath" %>
<%@ Import Namespace="System.Data" %>
<%@ Import Namespace="System.Data.SqlClient" %>
<%@ Import Namespace="System.Web" %>
<%@ Import Namespace="System.Web.HttpContext" %>
'### -------------------- Update Section ------------------------------- ###
Dim sharedConn As New SqlClient.SqlConnection("Data Source=ServerName;Initial Catalog=DatabaseName;User Id=UserID;Password=Password;")
Dim cmdUpdate As System.Data.SqlClient.SqlCommand = sharedConn.CreateCommand()
Dim strUpdateCommand As String
sharedConn.Open()
'### Declare Variables for XML Parsing
Dim sXMLString As String = ""
Dim sFormitem As String
Dim sRPath As String
Dim sPath As String
Dim iRangeLength As Integer
Dim iRowLength As Integer
Dim iRangeCounter As Integer
Dim iCounter As Integer
Dim oXML As Object
Dim oRNodeList As Object
Dim oRNode As Object
Dim oNodeList As Object
Dim oNode As Object
'### Get XML that was sent from SWF file
For Each sFormitem In Request.Form
sXMLString = sXMLString & sFormitem & " = " & Request.Form(sFormitem)
Next
'### Load XML into object
oXML = Server.CreateObject("MSXML2.DOMDocument")
oXML.async = False
oXML.validateOnParse = False
oXML.loadXML(sXMLString)
'oXML.load(sXMLString)
'### Declare the Variables needed to load XML values then use in SQL update command
Dim pID AS Integer
Dim strField1 AS String
Dim strField2 AS String
'### Use XPath to get the data
'### Find the number of ranges or variables to be exported
sRPath = "/data/variable"
oRNodeList = oXML.documentElement.selectNodes(sRPath)
iRangeLength = oRNodeList.Length
For iRangeCounter = 0 To iRangeLength - 1
oRNode = oXML.documentElement.selectSingleNode("/data/variable[" + CType(iRangeCounter, String) + "]/row")
'### Write out the data set for the range
sPath = "/data/variable[" + CType(iRangeCounter, String) + "]/row"
'### Find the number of rows for the range
oNodeList = oXML.documentElement.selectNodes(sPath)
iRowLength = oNodeList.Length
For iCounter = 0 To iRowLength - 1
oNode = oXML.documentElement.selectSingleNode("/data/variable[" + CType(iRangeCounter, String) + "]/row[" + CType(iCounter, String) + "]/column")
pID = oNode.text 'Get the value of the first field
oNode = oNode.nextSibling 'Move to the next field
strMetric = oNode.text 'Get the value of the second field
strComm = oNode.text 'Get the value of the third field
strUpdateCommand = "Update TableName Set Field1 = '" & strField1 & "', " & "Field2 = '" & strField2 & "' " & "Where ID = " & pID
'Response.Write(strUpdateCommand & "<br>")
cmdUpdate.CommandText = strUpdateCommand
cmdUpdate.ExecuteNonQuery()
Next 'Write a blank line before the next range starts
Next
sharedConn.Close()
sharedConn = Nothing
cmdUpdate = Nothing
greg.wayne (BOB member since 2010-09-28)
