Hi Frds,
The requirement is as below:
If a user is running a report via inputting a date in prompt.If report doesn’t have data for the corresponding date.It throws a message ‘NO DATA TO FETCH’.
Whether there is any way to hide this message so that if data is not there pertaining to valus given by user,the report should not throw any message.
I have come across this question a number of times in this board.I don’t think there is a straight forward method to hide it. Since you are using DeskI, you could think of some SDK solution(BeforeRefresh).
