Hiding of columns in Web I
I took cross tab , I applied formula to each cell(Varies for each cell). If any cell have no data for the formula then I should hide that cell…!!
Is it possible??
Can you please help me…
BOCP (BOB member since 2007-07-02)
You may be able to test for nulls and white it out with an alerter.
The details you have given are quite sparse, so I’m unable to elaborate further…:).
Ok…!!
Let me explain clearly::
I applied formula to a cell like follows:
=Sum(If(=“US” and =“2007”)then )
If the formula results “” then am getting cell with no data. I should hide this cell if it contains no data.
I think its clear and you understood…!!
Hi Kishore,
As Mak said,
  1. Create an aleter.
  2. Define the condition as when the Sum(…) is null
  3. Then, define format section.
  4. To hide the column make the border as None and set the color as the background color of your report.
GowthamSen :india: (BOB member since 2006-08-31)
