Hiding blank rows
Hi Guys,
I am designing one ad-hoc report that needs to show Person Name, Address Line 1, Address Line 2, City State Zip Code. For many person, Address Line 2 is blank. We would like to hide this row when this is blank and move up city State Zip row.
Format of this report is like:
Person Name
Address Line 1
Address Line 2
City State Zip Code
How can i hide this row when this is blank in WebI xi r2.
J WOOD
wood :nepal: (BOB member since 2006-06-05)
Apply filter on that dimension, set operator as"is not null" then it automatically filters out the value which is null.
madhu kothamasu :us: (BOB member since 2007-07-31)
The address Line 2 doesnot have null value in database. If no information is there on this column, it is simply blank in our SQL Database. So if i use IsNull() function, it doesnot make any sense.
I appreciate anyone’s help on this.
J WOOD
Try couple of these,
Flag=If Length(Trim([Address 2]))=0 Then 1 Else 0
see if you still get 1 for the above flag. If you get then you can filter out Flag=1
KhoushikTTT :us: (BOB member since 2005-02-24)
Y’all are missing the point. :slight_smile: The original poster doesn’t want to filter out the record, they just want the row (meaning a cell in this case) to not be shown if / when there is no address line 2.
Here is an idea. First, combine the two lines of address into one object using a concatenation. Then include a return character only if the second line of address is not null. In pseudo code:
= [Addr Line 1] + if(not(isnull([Addr Line 2])); chr(13) + [Addr Line 2];"")
Then set the wrap attribute on for that cell. I believe that - or something like that would work the best. I didn’t test the formula so the parenthesis probably don’t match but hopefully you will get the idea.
Thanks Dave. I appreciate your help.
J WOOD
