BusinessObjects Board
Hiding a combobox in print functionality in Dashboard
I am building a Dashboard in which I am using a combo box which I don’t want the users to see it.For that I have placed combo box behind all the other components.In preview mode it is not visible.But when I take a print out of the dashboard the combo box is visible.I have made its text as well as it’s background as white still it’s borers can be seen.Is there any work around to achieve this…
I hope I have made myself clear.
Any help on this will be appreciated.
User0207 (BOB member since 2013-09-21)
[Moderator Note: Moved WebIntelligence XI to Xcelsius - Crystal Dashboard Design]
Try to place the combo-box in canvas, somewhere at either corner of the Canvas, now shrink the size of the canvas which will eventually hide the combo-box, Hope this helps, thanks
mohdfahad (BOB member since 2012-08-09)
You could also add a background component, the same size as your canvas, layered with the combo box all the way in the back, then the background component, then the rest of your components. You could also check the option to “Block mouse events”.
~Roxanne
Sr BI Consultant
InfoSol
RoxanneP :us: (BOB member since 2006-08-07)
