Hiding a column
Hello All,
I have a calculated column involving nested “IF” statements. I have to create three different tabs with three different values. I have put the filters on three tabs and now want to hide the calculated column. How do you hide a column? Alternatively, how do you put a filter at the report level?
Thanks for your help.
Purnima
prnmsharma :us: (BOB member since 2008-03-18)
Check http://bi.stieper.dk/tip-hide-coloumn-in-web-intelligence-webi-145.
There is no option in webi report to hide any specific column.
You can try this.
Resize the Calculated column to minimun size. Then change the background color of the column to color matching to your background color of the report. Remove the borders for that column if there are any. Its all about formating.
Sukesh
sukrav :india: (BOB member since 2008-01-29)
Yes, there is no inbuilt feature to hide a column in Web-I. But the link I suggested talks about a trick to hide a column in Web-I.
should be able to find a workaround using ALERTER
Eljo :us: (BOB member since 2005-08-10)
I have a similar problem…
The data wont show but the empty row comes which is not desirable…
How to do it…? :hb:
cause in a column I want to hide only specific rows and not all
shukla :india: (BOB member since 2009-08-06)
Then apply a filter. :idea:
Moderator Note: Ah, I see your other topic here. Please do not cross-post. It leads to fragmented discussions and is against our forum rules. I’m locking this topic now.
