Hide Column
Hi Guys,
Is there any way i can hide a column only on first day of the month, I searched the forum but i didn’t get any idea. Can anyone please help me out
Diggy
Diggydee (BOB member since 2009-08-27)
Create an alerter that does this for you. Essentially the alerter would change the font and cell format to transparent when a date is equal to the first day of the month.
SteveBickerton :canada: (BOB member since 2002-08-15)
Hi Steve,
Thanks for reply, Only font is available for format, I didn’t see Cell for format. Can you please explain me how to make cell transperent. I will be very grateful to you
Diggy
you change the background also notonly font. check in the “edit format” by selecting the cell
rajkiransri (BOB member since 2005-04-07)
Can you guys please help me how to make column transparent using Alter, Any hint is appriciated
I am not suggesting alerts.
Put the column end of left-side or right-side.
Select no borders for the cell which you want to hide and with white colour for the border.
Paint the back ground with white colour, select the text colour white.
Try it will works.
Arjun (BOB member since 2008-07-28)
To selectively hide the column based on a day of the month, you can use Alerters (which can get tricky if you want alternating row colors) or just use variables and formulas.
Create a variable such as vDayNumber
=DayNumberOfMonth(CurrentDate())
Then for the columns, create a formula like
=If([vDayNumber]=1;"";[yourColumn])
You can do something similar to display the column heading. This won’t change the width of the column, however. The Rich Client manual says “You can
choose to display or hide empty tables, rows or columns” but I can’t find that check box in the properties tab. If you select Autofit Width, the narrowest you can go is 4 px.
charlie :us: (BOB member since 2002-08-20)
U cannot hide any column in Business Objects . If u want to hide u have tochange cell properties by changing background to white with no borders and font color white
yalisis (BOB member since 2009-07-27)
You can hide the column in DeskI report :slight_smile:
AFAIK, you can’t change cell properties selectively, based on a condition such as day 1 of month, without resorting to the SDK. The OP had a requirement to hide the column on the first day of the month.
Using Alerters or formulas, you can selectively display another object, or even text such as “N/A” or “Day 1” when the condition is met. This doesen’t really hide the column; rather it replaces it with something else.
Guys,
I appreciate the time you spent, i used Alert as Charle suggested…it works for me…thanks a lot for your help guys
Good Day,
It seems that you have solved your problem, but for the additional info for those who are looking for some workaround in hiding a column in webi THIS trick might help.
-John Vincent
jvmauricio :philippines: (BOB member since 2009-08-03)
Good day. Thanks for the link.
