A quick guide to hide a column in Webi
If you want to hide a column in webi simply use alterters in the following way, lets say we want to hide column A, drag Column A object into Column B an then set an alterter on column B to say when Value A = Value A then show Value B, this means that the column displays Value B but if you click on thje variable it is actually value A, this means no nasty white cells or very narrow columns in your webi reports.
Col A Col B Col C
James Head (BOB member since 2005-02-14)
