Hide a component based on other component
I am designing a dashboard where I have 2 list boxes Store and Product . Now, I want one of them visible/enable depending on my input to a dropdown.
I am finding it very difficult to change it through Alerters. Is there any work around for this??
jayesh_deshpande (BOB member since 2009-07-21)
if you want to show/hide a component you should be using
Behaviour >> Common >> Dynamic visibility of that component.
Naresh Ganatra :us: (BOB member since 2004-04-09)
dynamic visibility dude set-up " status & key ‘’ things you can make hide/visible upon your selection
best wishes
silverware (BOB member since 2011-08-25)
I got It. However I would like to understand the functionality of dynamic visibility.
Req:
I want to hide/show a list boxes(Product and Store) based on selection in my radio button. Also, when I user will select Product on radio only product related chart should show up and vis vesa.
Immplementation:
I have to add few option like “All Store” and “All Products” in list boxes so I have used a combo box to make data flow and then filanlly I provide this refined data to my charts.
Now, when I try to hide this combo along with other components, chart does not change its values according to selection from list box. However when I remove dynamic vibility of combo everything works fine.
Is dynamic visibility make combo disable??
You are making everything complicated difficult to get you but what are your requirements .Just that i have created a dashboard i am attaching it along with the data wud be easier to understand .
I have attached in pdf format as it does’nt allow me to attach xlf change the extension to swf.
Let me know if it works for you .
Inventory_Breakout.pdf (11.0 KB)
county :india: (BOB member since 2011-08-04)
dynamic visibility doesn’t effect data flow its for hide/show type … you can hide combo box wen required u can UN-hide that … once mail me .xlf file to me i will check and correct your query
mail id: sunil24sunil@gmail.com
your PDF file not getting opened in my system is that corrupted better upload other here
