Hidden tables in BOXI R2
Hi Alll,
when i am issueing a query using query builder.
select SI_ID,SI_NAME from CI_INFOOBJECTS where SI_PROGID=‘CrystalEnterprise.Webi’ and SI_INSTANCE=0;
To See ALL Webi Reports
my questions are
1)where is the CI_INFOOBJECTS table resides because in my installation i have only 5 tables(below) then where is this table coming from. where does this table store.
CMS_Aliases5
CMS_IdNumber5
CMS_InfoObjects5
CMS_RELATIONS5
CMC_VersionInfo
  1. how can i see this table metadata(columns information).
Can any one solve this ?
please
Thanks in advance
ash
asni (BOB member since 2007-04-06)
am i post this in the wrong forum?
any one please give me information about CI_INFOOBJECTS TABLE 1
ash
The CI_INFOOBJECTS is stored in the system database as binary encoded data. You cannot use normal sql tools to view the column values. The code behind the Query Builder can translate the sql and return data. The only other way to get data from the system database is to write code using the sdk.
blair :canada: (BOB member since 2006-11-17)
Right it based on the Xi sdk. It’s a good start to develop more sophisticate tools to query the security.
hi
its valuable informtaion.
then how can i know what are the available tables in system database.like any pdfs or any other sources
how can i see all of the tables & their columns…
please.
Once again Thanks
ash
Again there is nothing to see within the CMS tables. You may have a look to the sdk documentation.
Thank you smith such a fast response
here i am using the table CI_INFOOBJECTS like this what other tables are available. thats what i am asking.
as your last post in which SDK documentation i can get this information
Thanks in advance
ash
This post can help you.
SDK documentation is available on OCS website.
Yes Smith,
i already gone through this topic, after reading this only i got the question(this whole post). but what i am asking is.
CI_INFOOBJECTS
CI_APPOBJECTS
CI_SYSTEMOBJECTS like these what else hidden.
can i have any path for OCS website.& where which SDK DOc can help me?
please Smith
Thanks in advance
ash
SDK can be downloaded at http://diamond.businessobjects.com/. Please keep in mind that it is not for the faint of heart. You need to have pretty solid programming background.
Hope this helps.
Apparently no longer available there. And can’t find where to find this now :crazy_face:
yep :yesnod: documentation gives you only an overview on the possibilities. You need to search and find solution by yurself.
They changed the site a little since the last time I visited. But it seems to be more organized. The following link at the developer site grouped the SDK by versions…
Thanks you substring & Smith.
thank you very much. really appreciate, i will gothrough
this
regards
ash
yes i know programming at good level.
i will go through
thank you alll
regards
ash
Hello Everybody,
I think BO uses something like “Hibernate” to map SQL request on Java Object.
FYI:
CI_INFOOBJECTS will help you to find datas about BO Objects (webi - deski reports, crytstal), Corporate Folders, Inboxes, Categories, Personal Foders
CI_APPOBJECTS will help your to find datas about Universes and Universe Folders.
CI_SYSTEMOBJECTS will help you to find datas about Groups, Users, Server Groups and Servers.
(through Query Builder of course)
Alexandre.
360View (BOB member since 2007-08-08)
thanks for your information Alexandre
regards
ash
Where are these hidden tables located. Are they part of file system or on database?
Taurean
Taurean (BOB member since 2005-08-15)
I thought one of the earlier posts has stated very clearly. These hidden tables are in the system database. They are in binary format and not readable by normal RDBMS tools. You can query these tables with Query Builder because it is wrapped with BOE SDK.
These tables are the 6 CMS tables. They make the links between the Files located on the server and the rights set on them. You also query them using CMS sdk.
BR
Sebastien
Do you mean the tables brings information from filesystems too when I use Query Builder. It is just not tables alone that provide whole information?
In other terms, if I delete the file systems, I query wouldn’t run even though it has whole information on DB tables?
Taurean.
