That makes me worried, my tests were run from the 2.51 / 5.01 cd, and I still only had docs show 1 of 3 tries.
Brent
WEBI 2.5
The patch is 5.0.1 and 2.5.1. Everything you need comes on 2 CDs
Brent
WEBI 2.5
When I attended the Conference in San Diego the techs told me the patch was to fix the following problem.
Without the patch: Users would have to move all personnel documents to Corporate Documents - then do the upgrade. Users would then move their documents from Corporate back to Personnel. If they didn’t move their reports to corporate - after the upgrade they wouldn’t be able to see the reports.
With the patch: No action required. Users would see their documents fine in Personnel Documents.
We are in the middle of upgrading our Web servers with the 2.5.1 patch now. When I tested the 2.5 you couldn’t see any personnel documents. I have not had the chance to test out the 2.5.1 patch as yet. I had thought that this would also solve your problems. There maybe something else going on since you can see them sometimes and not others.
Brent
WEBI 2.5
Web archives (24 hrs. a day now!): listserv.aol.com/archives/busob-l.html
