[Teradata][ODBC Teradata Driver][Teradata Database] ‘{’ ('7B’X) is not a valid Teradata SQL token.
for the below Filter definition in Universe.
CASE WHEN @Prompt(‘Select Begin Date:’,‘D’,Mono,Free) BETWEEN ABC.START_DATE AND ABC.END_DATE THEN ABC.START_DATE
ELSE
CASE WHEN @Prompt(‘Select End Date:’,‘D’,Mono,Free) BETWEEN ABC.START_DATE AND ABC.END_DATE THEN ABC.START_DATE
END END
Remove the “ELSE CASE” in the middle and 1 “END”. It should read like this:
CASE WHEN @Prompt('Select Begin Date:','D',,Mono,Free) BETWEEN ABC.START_DATE AND ABC.END_DATE THEN ABC.START_DATE
WHEN @Prompt('Select End Date:','D',,Mono,Free) BETWEEN ABC.START_DATE AND ABC.END_DATE THEN ABC.START_DATE
END
