Help on date issue
Use calander object for selection. A date must be entered.default is current date minus six months-----
Bandreddy :us: (BOB member since 2011-05-04)
What’s the question?
Kinda understood the question.
Having a dynamic default value for date prompts is on a lot of people’s wishlist, but as yet BO does not support this.
dfoster99 :uk: (BOB member since 2010-11-05)
I Have a date object in my universe
i need to create a condition using the date object and show the data between Todays date and Todays date - 6 months.
–Orace DB
–Drivers used ODBC
A simple way to do this is to create an object that derives ‘today-6month’ and another for ‘today’
You can then reference these objects in your query against the date object (i.e. date object between ‘today-6month’ and ‘today’)
I cannot get the sysdate suing sql in my universe and also not able to use some functions like addmonth()…
i tried this syntax…i know @prompt in the below syntax need to be fixed…but is there anything else you find wrong with this syntax
between (CASE WHEN @Prompt(’Enter the date’,'A’,{’01/01/1900 12:00:00 AM’},mono,free,) = ‘01/01/1900 12:00:00 AM’ THEN trunc(sysdate) – 1 ELSE to_date(@Prompt(’Enter the date’,'D’,object,mono,free,),’MM/DD/YYYY’) END) and add_months((CASE WHEN @Prompt(’Enter the date’,'D’,{’01/01/1900 12:00:00 AM’},mono,free,) = ‘01/01/1900 12:00:00 AM’ THEN trunc(sysdate) – 1 ELSE to_date(@Prompt(’Enter the date’,'D’,Object,mono,free,),’MM/DD/YYYY’) END),-6)
Is this a good approach
my universe screen shot shows the liberty(which i cannot use) with date function attached…
–Oracle db
–ODBC drivers
Web Help.doc (92.0 KB)
Build the date objects separately in Designer. The code for these is shown in a “sticky” topic at the start of this forum.
Create an object for TODAY
Create an object for 6 MONTHS AGO
Then in your report, simply drag and drop, so your filter is something like:
WHERE DATE BETWEEN [TODAY] and [6 MONTHS AGO]
Debbie
